Project Part Out!
Most parts are brand new unless noted. Some parts have been bolted on, but not used. Located in NKY. Can text me at 859-380-0469
- Holley sbf black Hi-Ram base w/ fuel rails PN:300-274BK - $750
-Holley Hi-Ram fabricated top GM tb pattern PN:300-286 - $225
-Siemens Deka 80lb EV1 set of 8- ran for less than 5 mins- look new- $300
-Holley Terminator X 550-910- ECU never installed, no 3.5” screen- has LS wiring harness, but some connectors have been modified for SBF application- $900
-Precision Performance Products powerglide kwik-shift II w/ floor bracket- $300
-Tig Vision 79-04 Mustang PPP Shifter mount PN: TV7122 - $100
-Borg Warner S366 .91 AR divided jornal bearing- $650
-Treadstone A2A intercooler - $250
-Edelbrock elbow 3849- $150
-Flowtech sbf turbo headers PN: 12164FLT- $200
-Promaxx Project X 210cc heads w/ ls spring upgrade- hydraulic roller - $1350
-SFI 157 tooth PG to SBF bellhousing- $275
- Ebay sbf hot side with emusa waste gate, heat wrapped - $300
-Hayden 525 remote mount transmission cooler w/ fan -$80
-Mr. Gasket sbf electric water pump PN: 7023BG - $100
-GM ebay 102mm throttle body- $35
-Thermal Zero turbo blanket PN: tz32258-b - $50
-Ford Contour electric fans and shroud- $60
-Accufab Ford to GM throttle body adapter w/ GM IAC- $50
-Flaming River U joint for stock SN95 cloverleaf shaft to manual rack- $120
-PRW 50oz sbf flexplate flx-30215- $50
-79-04 PS Racing sbf k member- used - SOLD
-SBF solid motor mounts- used -$25
-DJ SFI engine diaper- SOLD
-Edelbrock 3620 sbf fuel rails- $125
-Custom built black coated sbf valve covers with D585 LS coils and 12AN fittings- $225
-MSD 85221 8.2 sbf cam sync- has connector cut off- $225
-Innovators West #931 sbf crank trigger bracket- $120
-Jim Miller mid-lift sbf 1.6 ratio roller rockers- used- $200
-Trick Flow 6.750 .080 pushrods- used- $60
Ill take the
Venmo or PayPal?
Well shit, I cant read and that mount wont work with my B&M shifter. :-(
I am interested in the Contour fans.
I’ll shoot you a text.
